That's one way to hold a tankless coil in
I've seen many uses for vice-grips but this is special!!
  • Weezbo
    Weezbo Member Posts: 6,231
    i must say that is an unusual configuration of vice grips..*~/:)
    one other observation, that unique placement of an open end spanner with the epoxy honestly never occurred to me either.
    i guess i am missing the boat:)
    There are somethings money Just cant buy .:)
  • lee_7
    lee_7 Member Posts: 457
    Was this a temp. fix or a perm fix?
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    vise grips
    Send the photos to Vise Grips....you may start a new ad campaign for them....looks like plain old yankee ingenuity to me......whatever works in an emergency
  • Bruce Stevens
    Bruce Stevens Member Posts: 133
    I went to do an annual service
    on an oil fired boiler about fifteen years ago, you guessed it leaking tankless gasket guy wanted it fixed pronto however I had no gasket. He wanted me to just tighten the bolts but looked to corroded to touch told him to leave it be until I got one. Next morning he is in the office tried tightening it himself and you guessed it he broke a bolt. I swung by and popped on a pair of Vise Grips ordered the gasket the Vise Grips are still there he just likes the reminder.
  • 1974bobcat
    1974bobcat Member Posts: 18
    They had been there a year or so, I was giving a quote to replace it when I found them.
    BobCat
  • Frenchie
    Frenchie Member Posts: 113
    Broom handle?
    How does the broom handle fit into this equation?
  • Joey B_2
    Joey B_2 Member Posts: 24
    what do u guys do when the bolts snap??? do you drill and retap? or use some kind of screw extractor?
  • Bruce Stevens
    In a WM
    I drill a small hole in the center of the bolt and spray PB Blaster in the hole and outside if enough stud is outside I clamp on vise grips and tap until it loosens, if not so lucky drill bigger and try extractor if still no luck drill bigger and dig the threads out, rarely do I have to re-tap.
