GB Install / Darin Cook
As long as you have a straight chimney and enough room inside the tile, 3" pvc goes right down the chimney. Buderus gives some various vent schematics in their install manual. You definitely have to use the condensate tee on those long runs. In fact unless you are immediately putting 90's and terminating out of the side wall, you always have to use the condensate tee. I have the pipe supported at the top and bottom of the chimney run. You can pull the combustion air out of the chimney chase itself, it is still in the same pressure zone as the exhaust. Thanks for the questions.
Darin
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=509&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
