Boiler sizing dilemma
David Nadle
Member Posts: 624
I'm trying to find a replacement boiler. I've measured the radiators at 280 ft^2. My old boiler is rated at 300 ft^2 and has a 5" flue.
Before I had the idea to replace my boiler I had my chimney lined. They sized it to the present appliances and I got a 5.5" liner.
All the boilers I can find today with 5" flues are a bit undersized, ranging from about 1% to 8% less than 280 ft^2.
The Burnham I liked is about 3% under. Presuming that I will insulate the mains, would you say I can get away with it or do I need to take steps to fit a boiler the next size up?
Hmmm 5" is small . .is this a new construction?0 -
Replacement of 30+ year old steam boiler
Not new construction. Sorry if I wasn't clear.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
