HVAC Program
Weezbo
Member Posts: 6,231
anyone give it a perusal? something that happened, was it gave me a Too many boilers message ...it was when i was placing the pieces in the boiler room for a new 20000 sq ft shop. it has some design features that i was going to eliminate....seems the program decided to eliminate the third boiler which is a clean burn... curious is it just me ?
the pump block and the x block symbols are now on the tool bar under hydronic piping however they are shaded out...is that something else i am not doing right or is it only there for the taco load match design when it is selected? well, ... it seems like it has some new things ...i have not learned the navigation just yet...try opening or dropping down the pump block.....talk to me ..i like all these programs maybe i will go check the new instructions on line...
well, if you get a chance , check it out... it has some new steam features
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
