Pex Fittings
Ted_9
Member Posts: 1,718
I've been using pex for 14 years and have had no failures.
I guess I'm lucky.
I guess I'm lucky.
Pex Fitting Question
Has anyone seen failures on 1807 crimp style fittings? I have seen a few in my area and I was wondering if I was alone?0 -
I personally...
have not had any failures, but i have only been using pex products for about a year.
There was this thread kicking around about a week ago regarding recalls.
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=347753&_#Message347753
Makes me nervous, back to copper!
JimThere was an error rendering this rich post.
Thing to remember
Most Pex systems have a 30 yr + warranty
Copper has none!
Most failures are caused by installation errors and product mismatch and substitutions.
Can't tell you how many "failures" were failure of the contractor to crimp the rings or clamps.0 -
What kind of failures?
leaks? cracked fittings? Out of tolerence?
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Pex
Polybutelene (sp) Everything inclding the installers were blamed. Is it still used?0 -
Excellent
Wow, first time I have heard or seen this
Debunks the PEX Reps sales pitches!!!
Thanks!0 -
Poly ...
is still used everywhere BUT the USA...Still plenty of systems out there w/no problems....most of those issues were the aluminum crimp rings on acetyl fittings...kpc
pex fittings
its only anout the crimp 1807 brass fittings not the press (bronze fittings.
if anyone wants to read up on the problem go to http://www.zurnclassaction.com0 -
warranty on copper
it is 50 years on the copper but there is none on the connection (sweat joint) but there is on the pex connection.
now if you were using Viega ProPress copper fittings then you would get a 50 Year on fitting and the connection0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
