30-32\" neo angle shower?
Robert O'Connor_12
Member Posts: 728
Not knowing which state you are from and which code(s) are in force, I'd go for the 32"x32" because typically the codes require a minimum of 1024 aq. inches. If you use a prefabricated base the "clear" floor area must be 900 aq. inches, the compartment shall provide for a 30"inch diameter circle with the door closed.
Robert O'Connor/New Jersey
Who makes a 30" or 32" neo angle shower kit?
Thanks in advance, Adam0 -
MAAX DOES...ITS A ROUNDED FRONT0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
