help
david_44
Member Posts: 4
I am really wanting to do this with low pressure,the dryers are connected now to an existing heating system in another location,they do work now on low pressure. Thanks again David
steam sizing
I know Dan is the steam guru so i am here to hopefully get some HELP. I need to size a new steam boiler for a system of my design for 3 OLD steam felt dryers. All 3 have 3/4" supply and return with traps on the return. My big question is how do i figure how many square feet of steam i need to supply 3/4" black iron pipe???? I would gladly take all advise and suggestions. Remember this is not for heat but kinda commercial steam, thanks. David0 -
YOU MIGHT NEED A HIGH PRESSURE BOILER .0 -
commercial steam
I would talk to some of your local reps that handle these type of boilers, sounds like something that would be used for a dry cleaning plant.Heres a link for some that I have used http://www.columbiaboiler.com/industrial/CT/0 -
High Pressure
High Pressure steam gives me the Willies ...I'am always by the door when I build up one of them beasts.Not that it wlll do any good anyway if she blows. It will still cook me Medium Rare...Maybe I am just a puss... Nothing to add to this post but a thought......0
