Viessmann Vitodens venting specs for fire wall
GW
Member Posts: 5,137
Brad,
I'm wanting to pass througha two-hour ceiling. It's hard to explain the exact situation. I'll see if I can get the PE to go along with it. Thanks, GW
gotta pass through a two-hour
does anyone know where in the specs it specs out the metal/material for the vent piping? I need to dot I's and cross T's... new construction commercial job.
Thanks, Gary0 -
NFPA-90A
allows steel sheetmetal to account for a one-hour rating by default although not explicitly. The reason is that a one-hour partition can have a continuously duct pass through it without a fire damper. A transfer duct would have a damper. 1.5 hour ratings and up you need a damper. Not applicable to your venting situation, just some background.
I would enclose it after testing in a continuous 2-hour enclosure, essentially extending the partition rating along the vent system. You could also use Pabco or Fyre-Wrap (which everyone says is expensive but nobody tells you the price
We used Fyre-Wrap on a smoke control system to protect the fan and dampers as it passed from the enclosure to the outside."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
