Scale dissolver
Brad White
Member Posts: 2,399
for any miscellaneous metals not specifically tested with the product. I have seen the term used for cast zinc, sintered metal (think metal powder compressed into final shape), the ubiquitous "white metal", pewters and Chinese Mystery Metal...
Language like that will get you out of Warrantyville on the fast train.
-Ernie White, my Dad
Scale dissolver
While using a scale dissolver today on a water cooled condensor on an ice machine, I read the instructions(NO WISE CRACKS NOW!!) and part of what it stated was " not to be used on aluminum,die cast pot metals or galvanized" .What products in the HVACR field fall into the "die cast pot metal" catagory ? Thanks!0
