Aluminum Lined PEX for Hydronic heating good or not??
wayne_23
Member Posts: 3
aluminum lined Pex for Hydronic Heating Good or not??
Good.
Use it a lot as well.0 -
Good
Use it alot also.
Scott
In some cases
Tha PAP products shine. I like it for baseboard and panel radiator jobs. Less expension movement makes it a nice match for transfer plates and UltraFin applications. Large sizes in straight lengths are great for indirect and boiler room piping.
I don't like it for in slab applications. It dents, and sometimes kinks fairly easily when stepped on as it crosses rebar or rewire.
We have seen some pics of de-lam issues from time to time here.
My favorite is the Viega FostaPex. It is a full diameter pex with the aluminum layer around the outside, no de lam issues to worry about. It also has a protective PE layer around the aluminum for a very tough tube. The OD is a bit large for transfer plate installation, however.
They also have a nice fitting system. Good looking, stainless steel crimp rings and thick brass barbed fittings.
hot rod
I
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
