copper and aluminum
Andrew Hagen_2
Member Posts: 236
Actually, it's the aluminum that corrodes. It's a very low voltage electric circuit. If both metals are in contact with an electrolyte, the circuit is completed. If it's dry, it's like a battery with no cables connected.
From the sound of things, it might not be wise to let Brad drain his "electrolyte" near your bathroom baseboard. ;-)
Okay
so we all know that aluminum clips eventually rot out copper tubing. So am I under the wrong impression when I look at convection baseboard? Are those fins not made of aluminum?
Leo G0 -
only if
there is an electrolyte (sp) present. If the copper and aluminum are dry, as the outside of baseboard often is, then no electrolysis can take place.
Even copper and aluminumn in a moist environment get along fairly well, think AC coils, radiators, evaporator coils, etc.
Just don't add salt to the mix.
hot rod
Worst yet
> place.
> Just
> hot rod
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 144&Step=30"_To Learn More About This
> "Find A Professional"_/A_
DOG PEE the easy down home way to get alum fins off copper pipe. LOL J.Lockard0 -
Hot Rod- He Be Right
Hot Rod nailed it -it all has to do with the presence of electrolytes. Also the salt comment? Salt is hygroscopic in addition to being unstable. It will absorb moisture from the air then get to work."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
HAH!!!
> then get to work.
Darin
ok - I'll ask
In what form might one expect to see an electrolyte that would affect the baseboard, or any other fin tube type product?0 -
Bathroom
Right next to the toilet.
C'mon. You know that."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
If your
dog pisses on your condensing coil the fins disappear.0 -
Depends
on how often and how soon it rains0 -
The Moon
Rises in the East....
Do you have the microfilm, Comrade?"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
The quick
brown fix jumps over the lazy dog ... at midnight.
Brad, maybe you should sit or eat less apsaragus.
Scott
the strength of the electrolyte
is the difference. Generally fresh potable water is a weak electrolyte, distilled or condensate, weaker yet, and steam will not act as an electrolyte.
Salt water and acid are excellent electrolytes.
A good example being your car battery. Drain the acid and the lights go out.
So steam clean the baseboard next to the toilet or urinals for better HW baseboard life
Or use the SlantFin board designed for this service.
hot rod
I forgot about the Slant Fin product
"A big hit with those who miss.""If you do not know the answer, say, "I do not know the answer", and you will be correct!"
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 986 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
