water use, steam vs. baseboard
chris nichols_2
Member Posts: 1
Do steam system use significantly more water than baseboard systems?
\"In what way?\", he asked.
If you are asking in terms of initial water content, a steam system uses significantly less water. The piping is dry and the boiler is full to about 2/3rds. the way to the top. No argument there.
A water system would of course have a full boiler and piping.
(Both systems use the same water over and over again as a way to transfer heat. This is unlike a domestic hot water heater where you use it at the same rate it flows in.)
Now, operationally: Ideally, both steam and hot water systems should never need make-up water in a perfect world.
Realistically (I deal in reality), steam systems tend to use more water over time. There are a multitude of apertures; vents, drains, imperfect joints which can pass vapor if not sensible water outright. Plus a steam system requires occasional blow-down of your float type low-water cut-off to maintain it in a safe condition. What comes out must go back in.
A hot water system, any closed system for that matter, ideally and realistically should only require new water when a portion is drained for servicing.
Does that answer your question?
Brad"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
