sizing expansion tanks
Glenn Sossin_2
Glenn Sossin_2 Member Posts: 592
Check out page 4. That should help you.
  • Bob_36
    Bob_36 Member Posts: 83
    I want to size an expansion tank for my system. I have six ci rads. I read Dan's book "How Come", to find the EDR. Is there a conversion to gal. or do I have to fill a rad with measured water to get an idea of total gal? I don't know if I can use a thirty gal size or need to upgrade to the sixty gal size. Any help to save me from filling rads would be appreciated.
  • Brad White
    Brad White Member Posts: 2,399
    Don't Sweat It Too Much
    The cost of a #30 tank is less than half of a #60 that I have seen. Worst case is, you buy two and they work together connected to the same point, for less equipment cost. If one fails you have a back-up too!
    What is your time worth compared to the cost of a second tank?
    There are tables on water volume of radiators and piping but it is not all that critical. Normal expansion from 50 degrees to 200 degrees is about 4 percent.
    Houses I have owned with CI radiators and in the 1500 to 1800 SF floor area range had water volumes of between 50 and 80 gallons given old iron pipe too, just a ballpark point of reference. Yes, your volume may vary but just for comparison there is a number for you.
    If you are off by 20 percent or say 20 gallons, that is 0.80 gallons to be absorbed. Not a huge amount. Just keeping it in perspective.
    Here is an alternate method I was taught years ago:
    The advice I was given by a favorite mentor, Ray Stevens, was to take the cubic volume of an imaginary box around the radiator and use 25-30 percent of it as the internal volume. It would still be likely high.
    Thus a 38 inch high column type radiator, 8 inches wide and 30 inches long (5.28 cubic feet at 7.49 gallons per) would have a gross volume of 39.5 gallons. 25 to 30 percent of this would be 10 to 12 gallons. Ray even suggested to throw in the run-outs as included in that number, it would be that conservative.
    Forget sizing based on the BTU output; those are averages based on small diameter copper pipe as you probably well know.
    -Ernie White, my Dad
  • Dave_4
    Dave_4 Member Posts: 1,404
    another site
    goto www.watts.com and type "expansion" in the search box - they have built in calculators for potable and non-potable and lots of other good stuff - i have used them to size my commercial jobs with 2 Turbomax’s, each with 119 gallons of "boiler" water - i also use dan's rule of thumb, for pipe volume:- take twice, the width, length, and height of the building, to calc the total piping len and plug that number into the pipe vol calcs - re-did a school with 5" steel pipe, used dan's method and it worked just fine and this building was odd shaped - just treated it as if it was a larger rectangle on the outside - i doubt though, that in your case, that you would need nore than a #30
  • Bob_36
    Thanks for the quick replys. As usual, your info was right on. Brad showed me how much I forgot or wasn't paying attention in math class. I couldn't figure how you arrived at the result. So I looked up the Watts' website and the chart listed a #30 as all of the posts suggested. Thanks again.
  • Ted_9
    Ted_9 Member Posts: 1,718
    install
    Gsossin, that pdf is a 2 page brochure and I didn't see where it says how to size expansion tanks. Is that the wrong pdf?
