Removing hot water heat piping
Brad White
Member Posts: 2,399
What you are describing, Craig, seems to be a hot water finned convector maybe.
The first question I would ask is, "is the Nuheat (electric?) up to the task of heating the entire space? Are you confident in that such that you can jettison the pod of what was reliable hydronic heat?
If you are, then your idea to jumper the supply and return is a good one, especially if you have a diverter tee or monoflow system or -best reason yet- a series loop system!
If you have a regular 2-pipe system AND it is served by a condensing boiler, I would cap them off such that the bypassed flow will not raise your return water temperature. If you have a conventional boiler and a 2-pipe system, I would put in a restrictor valve of some sort so that you do not waste pump energy rat-racing that flow without control. You may want to keep it valved on both ends in case your floor heating does not cut it, in the end. Just trying to preserve your options!
Brad
Brad
-Ernie White, my Dad
Removing hot water heat system pipe
I have a hot water heating system in my house. I am remodelling a bathroom, and putting in nuheat system in floor under tiles. AS a result, I need to remove the existing hot water heating pipe (looks like a 3/4" copper pipe with a bunch of coils attached to it).
Can I simply cut out the copper heating pipe and replace with a regular 3/4" pipe with no coils?
Craig0
