Glycol - Piping Pressure Drop
Brian_18
Member Posts: 94
http://www.taco-hvac.com/uploads/FileLibrary/SelectingCirculators.pdf
Document TD10 I found this document to be very helpful. If you throw the basic formula (page 3) on a spreadsheet, you can play around with the parameters and see the effect on headloss.
Do you know any sources for the effect of ethylene glycol solutions on piping pressure drop (other than ASHRAE)?
The curves in ASHRAE systems handbook changed significantly between 1980 and 2004 so I want a second opinion.
Specifically 20% solution operating at 30F.0 -
Pressure drop
Your friends at B&G have a very valuable tool called System Sizer. You can easily enter your pipe size, pipe type,fluid temp etc. to calculate pressure drop. Check it out here.
http://www.bellgossett.com/BG-SystemSyzer.asp0
