Mis-leading info
Techman
Member Posts: 2,143
Good Morning All! For example,the Super Boost #SPP8 say's on the front of the package it is good for comp's in the 1-5 hp at 90-277vac The vac part is not true and the 1-5 hp is mis-leading also. The SPP8 is good for any comp in the 1-5 hp range where that comp REQUIRERS a start cap rated at 189-277mfd at 170-277vac.No more and no less!!Every comp that can use a start cap has only ONE start cap that it can PROPERLY use.Just like any mis-applied part(start cap,run cap and start relay)DEATH will surely happen to that poor,unsuspecting compressor!!
