Solar Panel's and Cost???
scott markle_2
Member Posts: 611
from what I remember 30 deg. from true south orientation is about as far as you want to go, after this and there is steep drop in absorption.
I can imagine straddling the peek with a narrow 8 tube collector (like the one hr recently installed) this would require some custom work for the support structure but would achieve desired (required) southern orientation. I don't think east /west orientation would have much economic value (R.O.I.)
From what I understand one aspect of evacuated tubes is that some correction for off axis can be made by slight rotation of the tubes towards south.
East west exposure...:-)
I would like to utilize the east west peaks that are roughly 35'x15' and get a lot of sun. What am I looking at as far as cost, new technology that's available and overall potential power output......
Mike T.0 -
Thermal solar or PV?
For solar thermal panels Resol and a few others sell differential solar controllers with an extra sensor to "watch' panels on two different exposures. I know Oventrop has that control available.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
