Gravity hot water heat
Noel
Member Posts: 177
http://www.amtrol.com/extrol.htm
Noel
Noel
Expansion tank
We have an expansion tank that has went to leaking on a HW Gravity system The plumbing supervisor said to replace it with a little 3 gallon compression tank. I don't believe the system will work if that is done. What is the correct way to repair this?0
