Underground Piping
is available in the US, it`s a Wirsbo product. Not familiar with "Insulseal", but then again, hot rod`s never wrong!<BR><BR>Dave
Undergrd Piping
I want to run heating hot water piping between two (related) buildings. About 20 feet. What is the best way to insulate the piping? Will Armaflex last? The piping will be annealled copper.0 -
Chuck
Ever considered this stuff? Ecoflex I have used it for the same applications.
(Edit)-Sorry that was not a very good link, hopefully this is better.
Uponor-Wirsbo(Ecoflex)
Dave0 -
www.insulseal.com
is a product I use. Basically a PVC pipe with 2" of foam and a liner over it. Water proof, better r-value than pre-insulated dual tube systems. And it allows you to remove or replace the pipes if ever needed.
It's what I use for outdoor wood burners. A bit cheaper than then the flex type products and you buy just as much as you need.
hot rod
thanks.
Is the ecoflex available in the US?
What is the temperature/pressure ratings of the insulseal?0 -
Insulseal is a
condiut to slide your pex or copper inside of. They also offer the dual pipe pre-insulated coil product.
hot rod
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 985 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
