old forced air grates
lee_7
lee_7 Member Posts: 457
I have a customer looking for an old floor cast iron main return grate ( roughly 2' x 2'). I am located outside philly. It doesn't have to be in perfect condition, as it will be used in outdoor deck over condensor a shaddy contractor put under a deck with 10" between deck and top of condensor. Before you say it, the condensor can't be moved anymore because deck was just enlarged to entire yard (townhouse community). Just a bad situation I am trying to get to work a little better.
  • JJ_4
    JJ_4 Member Posts: 146
    Reggio Registers
    I have purchased registers from this company and they are of excellent quality:
    http://www.reggioregister.com/
    Here is the catalog page with 24x24...not cheap.
    http://www.reggioregister.com/downloads/30-31.pdf
  • Brad White
    Brad White Member Posts: 2,399
    I second Reggio
    They do have a "Printable Size Chart" (attached) which indicates grilles in the 29.5" square (32x32 OD) range as the largest and do have a 24x24 ID grille too which is 26.5" square. Check them out.
    -Ernie White, my Dad
