Superstor vs. Megastor?
ScottMP
Member Posts: 5,882
I figure the Megastore is a better product.
BUT ... I install what I think is Alot of Super-Stors and only a couple of Megastors. I've had one of the Megastores leak and found another leaker that we did not install ???
I don't know ...... But look at the odds.
I've always said the Super-Stor is a good solid product.
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Scott
If you had a choice...
If you had a choice between these two indirect hw tanks, which would you choose? I know getting a good installer is important, but I've got two quotes from two people who (I believe) know what they are doing, and one uses Megastor and one Superstor. Price difference between these two folks is negligible.
Looking at the spec sheets, the only thing I can see is that the Superstor loses less heat/hr than the megastor (0.7* vs 1.4* or something like that).
Any thoughts/opinions?
Bill D0 -
Pretty Equal
Both are excellent tanks. I cannot say one is better than the other.
The only major difference is the construction of the heat exchanger coil. The Megastor is stainless and the Superstor is Cupronickel.0 -
What I like about the megastor is that there is a cover on top that can be removed. You can take a hose and clean the tank out if needed.0 -
So much for a clear winner!
Thanks,
Bill0
