waterworks(slightly off topic)
The blue switch activates the apollo valve,the red one switches the DHW recirc. pump on or off.
  • Brad White
    Brad White Member Posts: 2,399
    What is the application/function?
    Curious what the application is. To cycle on HW recirc manually? To stop a leak if a pipe ruptures? Was there a stated features and benefits list?
    Not a challenge -it seems neat to the gadget minded. Just trying to see the application and hence value.
    -Ernie White, my Dad
  • American plumber
    American plumber Member Posts: 89
    for the gadget minded
    This system is installed in a home which is left unoccupied for various lengths of time.The access to the mech. room is seperate from the living quarters via a large (heavy) bulkhead door.I wanted to provide an easy,convenient way for the[elderly] owners to shut off the water supply & DHW recirc. The recirc. pump is cycled on&off by a vitotronic 200 & an aquastat,the red switch provides an additional break of power to the pump.
  • Brad White
    \"I see\", said the blind man....
    My only concern would be Legionella should the water remain stagnant and not be heated from time to time at least on the HW side. Other than that, neat and simple.
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Did that a long time ago
    In some vacation properties, but not with that degree of sophistication. Graded the HW/CW water lines to a drain, so no freeze-ups occurred.
  • American plumber
    Legi who?
    At what temp. do you supply your DHW ?(after the tempering vlv.)
  • American plumber
    Legi who?
  • American plumber
    biohazards
    Really? Do you think I should put [another] label on the red switch or maybe in fine print at the bottom of the stated features and benefits list;"Flicking the red switch off too often may cause deadly disease to form in your pipes"
