expansion tank
hr
hr Member Posts: 6,106
that sideways mounted expansion tanks have a shorter life expectancy then nipple up position. Does anyone else?
Mounted on their side, I have seen them last 20 years and more. Not bad for a tin can ;)
I'm more concerned about tanks mounted without adequate support. Like hanging from the nipple. Ever have a waterlogged one fall on your foot?
Connect them to a non barriered tube, high temperature hydronic system if you want to witness a short life span :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 742
    up, down, or sideways
    I've seen them mounted in every possible position, but does it really matter?
    The Amtrol instructions seem to say mount with the inlet up. I can see that might be the best practice, but is there a down side to mounting an expansion tank sideways? Strapped sideways under a stand would be space saving.
    So, what's the consensus?
    Larry
  • Bruce Stevens
    Bruce Stevens Member Posts: 133
    The only real concern by the manufactuerers
    is that if mounted where air can get trapped in the inlet then the bladder can dry and become porous
  • Josh_10
    Josh_10 Member Posts: 786
    That's my understanding too. The only other thing I would add that the manufacturer looks down upon is mounting overhead in a joist bay..
  • Bruce Stevens
    I with ya HR on that one
    I had a #60 Extrol come down and catch my fingers on a piece of angle iron didn't break anything but I was quite a while getting all my fingers to move normal again.
