Hydronic radiators without breaking the bank...?
Glen_8
Member Posts: 3
I knew there had to be something more reasonable out there. At first glance it seems to be exactly what I was thinking of (what I remembered from visits to Europe in another life)...I'll be looking at their tech info very closely. Thank you very much Andrew!
Don't suppose you've had any experience with these yourself? Do you by chance know the disadvantage (or advantage) of steel vs. what ever the other guys are using (>$1000)...is it just the possibility of corrosion long term or is there an efficiency hit?...or is it just the 'designer' stying that bumps the price so much?
Radiator options
We presently have an 42 year old home with old (but great) hydronic heat, presently in the form of baseboard radiators. We're doing some remodeling and would really like to free up some of the wall space the baseboard heating is taking up so we can put furniture more or less where we want to without blocking anything. Originally I wanted to go with floor radiant but the level we are remodeling has 8ft ceiling and a concrete slab. Not crazy about losing two or three inches for the solutions I've read about that there are out there for this situation so that I'm not heating good ol' mother earth instead of my home. Anyway, the next thing we thought of was to go with some standing radiators that we could put in the corners. We're just looking for something efficient and basic. So far we've only come across >$1000 bill-fold busters...any ideas on a good simple radiator source...or another way to approach the problem?
Thanks for the time...0 -
Steel Panel Radiators
Have you looked at steel panel radiators? I think the VEHA radiators area a good value and they are <<$1000.0 -
Form
Pete, make sure you fill out their heat loss form and send it to them. Don't just guess at the size radiators you need.
Just to let you know, I primarily install panels rads for customers and my entire house has them.
Panel Radiators
Yes, I have worked with the VEHA radiators as well as Stelrad radiators. They are very nice basic steel panel radiators at a good price. Most of the panel radiator manufacturers have a similar style as their "base model" panel rad. There is no disadvantage to using panel radiators. They can also be designed to work at fluid temperatures associated with condensing boilers if you decide to upgrade your boiler at some time in the future. Some people like the look of cast iron radiators, some prefer the look of Runtal panel radiators.0 -
Dianorm
Dianorm wall panel radiators are very competitively priced.
www.heatlines.com
Radson
sold by www.hydronicalternatives.com
Ted0 -
Recycle
How about the local scrap metal yard? Find some matching (or not) standing radiators that have the connections across the top and bottom. Hydro test to 50(?)psi. Have them sandblasted and painted. Add TRV's and you are in business, or at least heat.
Relatively inexpensive and they will make the Dead Men smile down at you.
Larry0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
