pipe fitters license
jackchips_2
Member Posts: 1,337
> If you have a plumbers lic in ma. can they <BR>
> grandfather you a pipefitters lic. We are <BR>
> starting to look at boiler projects that are <BR>
> pushing 1 million btus and dont want to get in <BR>
> trouble. If you have your oil license in ma. Does <BR>
> that allow you to work on oil boilers 1 million <BR>
> and up. Does an hvac license help with the mix? <BR>
> i dont want to start any projects and get in <BR>
> trouble. <BR>
<BR>
> trouble. <BR>
<BR>
ma pipefitters license
If you have a plumbers lic in ma. can they grandfather you a pipefitters lic. We are starting to look at boiler projects that are pushing 1 million btus and dont want to get in trouble. If you have your oil license in ma. Does that allow you to work on oil boilers 1 million and up.
Does an hvac license help with the mix? i dont want to start any projects and get in trouble.0 -
Hi Pete,
The grandfathering of Pipefitters licenses ended years ago and you now have to take the exam.
I had mine for a long time and gave it up. I do not know any of the steps required to now get one.
Others will have to reply to your others questions.
Good luck.
Jack0 -
Funny you should ask...
I am sitting for this test in 6 days. These days you will not get there without following the requirements to the letter... I came from another state and had to go before the license bureau and grovel before they accepted me. I was licensed for gasfitting and boiler engineer, there was no comparable license to the MA pipefitter where I come from. Your best bet may be to hire someone with the license...0
- 62 Biomass
- 114 Geothermal
