solar water heater
Jim_109
Jim_109 Member Posts: 45
what are the pros and cons of a solar water heater?
in terms of efficiency, costs, reliability etc., how good are they?
How do they compare to an indirect
When considering one what features, types brands etc. should I consider?
I live in the NYC area
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    I'm not a
    solar expert, but I have played one in a movie. (Just kidding, :P) An indirect is the tops. Hardly any standby losses and you get a lot of recovery speed depending on the capacity and efficiency of the boiler at the heart of the system. I would add solar if I had the money and heat up a pre heat tank that is piped in series with the indirect. WW
    hot_rod Member Posts: 26,587
    plenty of good choices
    of course you will need a back up system for non-sunny days.
    Generally the solar would be a pre-heat before the main water heater.
    if you have a boiler already you could install an indirect with dual coils. One for the solar loop, one for ther boiler.
    Or, Heat Transfer offers a high efficienct stainless steel water heater with a solar coil so both functions are in one tank.
    Or a solar tank with an electric element for back up.
    First determine how much hot water you need. then size the system around your needs.
    There are a number of solar contractors in the NYc area. contact one to get a site evalation first off.
    Properly cared for a solar thermal system should last 15, 20 years or more.
    There are plenty of players in the solar thermal market. Oventrop, Schuco, Viessmann, Buderus, Heliodyne, etc.
    Stop by a Barnes and Nobel and get a copy of Solar today mag for some more names.
    I'd go with a system that is common in your area for good dealer support and installation.
    hot rod
  • Jason_25
    Jason_25 Member Posts: 22
    I am also interested in solar. I want to install one in my own house first before any customers. I would like to use it for heating as well as for water heating. I have a munchkin boiler and superstore indirect with radiant. I am having difficulty finding any solar distributers in my area (nothern Michigan) - any suggestions
    Most radiant and hydronic contractors
    can install and sell solar components.
    Many of the hydronic and radiant manufacturers I mentioned above are sold in your area.
    Try the "find a contractor" button above, or the RPA website for a contractor/dealer near you.
    hot rod
  • Jason_25
    hot rod - I am a HVAC contacter I have e-mailed oventrop for a solar distibuter in my area but no answer Who do I contact at oventrop for their distibuter?
  • Joe Walsh
    Joe Walsh Member Posts: 1
    Solar Info
    Jason
    Call me at the office and I can help you.
    Joe Walsh
    Oventrop Corp.
    860-413-9173
