Convection vs Radiant in Hydronic Radiators
Mike T., Swampeast MO
Member Posts: 6,928
<I>In conventional, cast iron hydronic radiators (160-180 deg F. water temperature), what percentage of the heat output is through radiation and what is through convection?</I>
In a typical installation at least 75% via convection <I><B>while</B> the rad is heated to 160-180F during the heating cycle</I>. However that proportion of convection will decrease <I>when the boiler is not firing</I> as the radiator cools. It may also be difficult or damned near impossible to heat the rad to 160-180F in all but the coldest weather. BUT, as the radiator heats <I>to raise space temperature</I> its' proportion of convective output will increase. If that rad is however at just the right temperature to <I>maintain</I> room temperature <B>the percentage of radiation is maximized</B>.
<I>Does one size the heater differently if used as a convector vs. a radiator?</I>
Radiators are <B>designed</B> differently than convectors. You can use a radiator as a convector <I>if you raise the temperature</I> but it won't be as efficient at convecting were it designed to be a convector to begin with.
<I>How can one calculate how much a radiator is degraded in heating capability if a radiator cover is placed over it?</I>
Covers over radiators turn radiators into convectors! Unless designed as a convector it will require a higher temperature to achieve the same output.
Convection vs Radiation in Hydronic Radiators
Does one size the heater differenctly if it is used as a convector vs. a radiator?
Thanks.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
