Recent install
STEVEN MARKS
Member Posts: 154
I don't know. I never asked the homeowner about the buckett. No oil leaks while I was there.
Crown Install
Installed a Crown Freeport with a Crown 40 gallon Megastor. How did I do?0 -
not bad...
too bad you didn't have some cement blocks to bring it up off the floor...and the relay will be hard to read it that orinetation...neat piping. kpc
Did you set up
the burner with a combustion analyzer?
It's too bad you couldn't get some kind of isolating flanges for those circulators. That would have made your life easier down the road.0 -
analyzer
Yes, I did set it up with an analyzer. I work part time for a local oil company doing installs on the weekends. There are valves upstream of all the pumps and 1 ball valve on the main header. The expansion is blocking the view.0 -
I use a flex oil line atthe burner so that I can swing the door open for servicing. What is the bucket under the oil tank for? I hope not for catching oil!
A Buckett?
Under the Beckett?
Riello, now...
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
