tankless/aquastat
John@Reliable_5
Member Posts: 76
If both are used only for heat , turn it down to 115 for the summer. That will be high enough to avoid scale on heat-X. But if you are making [sink] hot water leave it at 180,use the mixing valve to control water temp, if this has you asking more questions call your service company to check
I have a steam system/force hot water system. The forced hot water system is a tankless attached to the boiler. Can I turn the aquastat down from the 180 it is set to now? ed0 -
what kind?
what kind of tankless do you have?0 -
It's a thermaflow. I also have a Bock 40 gallon for hot water. Is that 180 temp what is keeping the water in then indirect hot too? ed0 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
