Indirect water heaters
Patty G
Member Posts: 1
Hello,
I have a question. I understand that you can add indirect water heaters onto hot water boilers. Do you know if you can attach an indirect water heater on to a Steam boiler??
If so are there things you must do to make it work or is it only on certain types or brands? Please let me know! Thank you.
~Patty
~Patty
You Can
A bearing type circulator would be a better choice when used on steam . Even adding a strainer basket before would be wise.The gritty water eats them up...Piping to the indirect should be below the water line also..0 -
Use a Bronze Circ
Use a bronze circulator, not the typical iron type. It will last longer.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
