Cast Iron Baseboard Leak
Bill Parr
Bill Parr Member Posts: 1
Still made today is Weil-McClain and Burnham. Neither of which match the job I am looking at. 20-30 years ago there was, I believe US National. Does anybody know if W/M or Burnham push nipples will fit this older heat panel?
Anybody know if parts available? Where?
  • went down
    I went down to basement and found some national US baseboard raditors.... Took the weil mclain push nipples to check for sizeing... No problem, will works.. Make sure u clean with pipe wire brush and lightly pipe dope the push nipples... Good heating supply or heating shop will have them along u may need to rent the radiator assembly tool to do the job properly..
