Radiant heat
ScottMP
ScottMP Member Posts: 5,882
Ultra-fin require high temperature water ??
Kind of negates any savings of fuel
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Willie
    Willie Member Posts: 1
    Radiant Heat
    - If heat track plates are 1" off the bottom of subfloor will the proper heat transfer still take place? Floor thickness is 1 1/4" (extending plates down 1" would avoid nails damaging the Pex tubing.
  • Brad White_88
    Brad White_88 Member Posts: 11
    No.
    Contact with the sub-floor is everything. Nip off the nails and screw/staple the track plates snugly to the sub-floor.
    What you describe is one hand clapping.
    Unless you are running a high temperature system (and even then using a different emitter) you just have to make contact.
  • Weezbo
    Weezbo Member Posts: 6,231
    Plumbing Heating & electrical work done.prompt reply.
    reasonable Rates. contact.
    contact is one of the things that has to happen or it just doesnt communicate*~/:)
  • Pinball
    Pinball Member Posts: 249
    Unless of coarse. you use Ultra-Fin. Installed 3" below the subfloor.Perpindictu;ar to the joists, and alot of holes.
    There's an application for everything. Personally I'd rather drill than grind, but thats up to you.
