From our friends at Bell and Gossett
Weezbo
Member Posts: 6,231
got my Bell& gossett cap d:)
and two of the new pinner pumps for my injection systems. d:)
Bell & Gossett® Introduces New Hydronic Heating and Plumbing Products Catalog
Morton Grove, IL, June 19, 2006 - Bell & Gossett® has announced availability of a new, expanded catalog of its hydronic heating and plumbing products. The 20-page, full-color catalog A-50L contains descriptions, illustrations, dimensions and performance curves for the company's full line of circulators, flanges, pump relays, valves, air separators tanks, heat exchangers, parts and hydronic specialties including:
o Check-Trol™ isolation flow control flanges
o EASB-Jr enhanced air separators
o SSF stainless steel wet rotor circulators for potable water applications
o Larger size, three-speed NRF wet rotor circulators
o New BPX™ brazed plate heat exchangers for hydronic applications
For a copy of the new A-50L catalog, contact your local Bell & Gossett Representative, or visit www.bellgossett.com.
A PDF file for the catalog is at: http://fhaspapp.ittind.com/literature/files/1.pdf.
ITT is a leading manufacturer of centrifugal pumps, circulators, hydronic specialties, heat exchangers, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.0 -
Awsome web sight...
And don't forget to ask for your "System Syzer calculator" which is great for quick sizing and will basically wash the dishes...;-) or at least let you know the flow rate and the Cv value when doing so.....
Mike T.0
