Gen'l Cost for Heat Exchanger
Brad White_9
Member Posts: 2,440
are generally and for all purposes universally not discussed here for several reasons.
If you have specific information on your inputs and outputs, fluid temperatures and pressures, contact a local representative specializing in heat exchangers. I would suggest contacting Taco as a good place to start. They can put you in touch with a representative in your area and get you a real not a guesstimated price.
Good luck!
Brad
Good luck!
Brad
Gen'l cost for heat exchanger
We have paid for some repairs on an old heat exchanger and I think it is time to look into replacing the entire unit.
what is the general cost for a steam to hot water heat exchanger? During peak performance, we use about 700,000 pounds of steam.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 987 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
