Decision time on Vinyl w Insulation vs Repaint or Hardbyboard
hr
Member Posts: 6,106
spend some time at www.buildingscience.com
I attended Dr Joe's seminar a few weeks ago. A real eye opener.
Care needs to be taken as to how and where you install the moisture barrier under the siding.
The best way to screw up an old home is to add insulation and or siding then air conditioning, according to Joe. He had plenty of picture to prove that theory.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Maybe Constantin has some thoughts
Well amidst other various heating projects, it's contract time with our vinyl guy. 1920s colonial, westchester county, new york. We didn't want to paint due to lead dust from sanding--even with the vaccuum bags--and the continued high repainting cost over the years.
Vinyl--much as it goes against my purer, restoration instincts--offers the chance to add a 3/4" layer of polystyrene insulation board over the clapboards and under the vinyl for air sealing. (in addition to the blown in cellulose).
Hardyboard is way too expensive.
My only concern is the possible trapping of moisture by the vinyl--but as I understand it vinyl is installed loosely. I don't suppose the insulation will trap moisture. I would try to seal any holes/cracks in the clapboard with caulking before the job. Also vinyl hides what might be going on with the wood underneath.
This was an agonizing decision after months and months of considering other options. We even paid for a consult with a restoration company with one of the new low heat infra-red paint strippers, but the cost was sky high.
Any opinions on this?
Thanks,
David0 -
There will be no additional vapor barrier added over clapboards
Thanks. There will be no tyvek etc. added. The existing black paper under the clapboards will remain.
Yes I think Joe from building science is one of the ultimate authorities on this and due to the vapor barriers functioning differently at different times of the year habits may be changing. I've bought some of their books and have read other of their publications. Wish they had put me on a mailing list for the seminar you saw. I see he'll be in NY city june 26 for this mysterious topic: Compartmentalization: Enclosures and Equipment - Why Central Heating & DHW Systems are Un-American: Debate.
Thanks,
David0 -
We went with hardyboard for residing our dormers a few years back... it's great stuff, and I couldn't be happier with it. But our house is mostly brick, just two big dormers on the upstairs, front and back. If it had been the whole house, I might have had to beat down my purer instincts...
I think you can do vinyl and make it look good... just be very careful about the product and sizes you choose. Stay away from fake wood grain, and try to match the size and profile of your original wood. Or, drive around town and measure the clapboard size(s) of houses of comparable age that still have their original siding.
-Garret0 -
yes, sizing (width) is a problem
Our existing clapboard is 5" but to avoid a double seam every 12.5' we may have to accept Certainteed Monogram 4.5" which now comes in 16 and 20 ft lengths. Some fake grain looks unnatural, since in my experience, old painted clapboard is generally smoother without visible grain. Certainteed does a pretty good job on that though--they claim to imprint it directly from cedar wood planks. Is your aversion to the fake grain aesthetic?
The hardyboard as you know also has to be re-painted, though not so often. You also have to be damn sure you won't be expanding the house later therefore having to redo alot of that expensive work. They say pre-painted hardyboard is not the way to go since the installation process often messes it up and you have to repaint it again right away.
Thanks,
David0 -
My aversion to fake grain is mostly aesthetic, though I imagine a smooth will be easier to clean (powerwash) in the future. Original clapboards were sanded smooth... rough sawn cedar shakes are another thing, of course. It just bugs me when stuff pretends to be other stuff.
We got pre-primed hardyboard, and painted it before installing. There were a few nicks and scratches... nothing that required major repainting once installed. It's only been up a couple of years, but so far I'm happy with it. We'll see how long it holds up before needing more paint... I'm hoping we'll get 10-15 years out of it.
4.5" sounds pretty good... when we did ours, I ran all around town and took measurements, and found that original clapboards were either very small (2" - usually on turn of the century victorians) or in the 4-6" range (a bit later).
Good luck... sounds like a big project and a big decision... never easy.
Grained siding
holds dirt and algea. Get a Nice heavy gauge siding in the longest lengths you can find. Stay with light colors to create less noticable fading down the road. The vinyl has weep holes, so don't wory about trapped water. I don't think the foam helps much as an R value. More to give a nice level mounting surface.0 -
I think a major key to looks is how the trim is treated. Cheap contractors are butchers. I good contractor will maintain the size of the trim by sheathing it in aluminum.
While I would prefer natural siding, I now laugh all the way to the bank as my neighbors shell out $7000 every five years to paint their houses that start peeling in a year or two.Steve from Denver, CO0 -
Sounds like you neighbors have \"issues\"
Like lack of vapor barriers, some vapor barrier paint on the interior walls and a good air sealing of the inside of the walls will probably stop the peeling paint. Also I would never, ever install foam insulation on the outside of a home in a northern climate. In the winter vapor pressure from inside pushes moisture through the walls. If it hits a tightly sealed vapor impenetrable cold surface, you get condensation and then rot. If you install foam insualtion lossly, then it will breath the vapor, but you'll lose your R-value.
Boilerpro
Well that was the answer I was afraid of
that the 3/4" polystyrene insulation layer over the clapboards will trap moisture if installed tightly. I have read material from buildingscience.com and it is a bit hard to follow. (See attached pdf 'vapor barriers and wall design' if the Wall allows pdf attachments.) If you look from page 9-13 or so (starting from the RIGHT side of page 9) they seem to say that less than 1 inch of unfaced polystyrene is greater than one perm, i.e. semi-permeable. A number of dewpoint tests are performed at various relative humidities and temperatures.
Joe Lstiburek says, "...No assembly constructed in climate zone 4, 5 6 7 requires a Class I vapor retarder (i.e. a polyethylene vapor barrier)." (This is also from 'Builder's Guide to Cold Climates.') I know this goes against alot of long-standing building practices.
Perhaps installing the polystyrene loosely is the answer OR installing an HRV or ERV in my home to vent out humidity via controlled ventilation.
I have seen studies of some of the PERSIST systems, which use very thick external insulation that seems to work.
In a post last year, Constantin said, "...The exterior insulation simply has to be thick enough to ensure that whatever dewpoint can appear will only appear in the insulation.." (really talking about the PERSIST system.)
..."A properly sealed insulated exterior wall (EIFS is a favorite exterior covering.) [DG: what's EIFS?] will experience little to no migration of moisture as there is no mechanism for the air to transport the moisture to the sheathing. What little condensation could potentially happen is then allowed to re-evaporate into the house by not putting a vapor barrier on the inside. Some form of controlled air exchange will then preserve IAQ, control humidity levels, etc..."
I know this has been kicked around on the wall a bit; seems some of these issues always come to a head just as I'm close to going to contract.
Thanks,
David0 -
Yeah..
that's what I was talking about. If you get the insulatioin thick enough the dewpoint will be in the foam and condensation is not an issue. The only way to figure it out is to do a thermal gradient chart of the wall constuction and see what the temperatures are at the surface of foam. You've got me thinking about this again and I may just sit down and run a few when I have time.
Boilerpro
Paradox here: usual concern is moisture moving out of house
and condensing on its way on the wrong surface. (In winter anyhow.) But what's strange is that in the northeast house air gets very DRY, usually around 25% RH without a humidifier. So you'd think how much moisture could there be to worry about. (I have seen some condensation on the inside of our bedroom windows some mornings which quickly dissipates when the heat comes on and we open the door.) We have a four degree night setback.
I know that in summer the moisture supposedly reverses direction and comes IN, which is why vapor barriers can be problematic.
As far as a thick enough insulation to prevent condensation where it can be injurious, I do not really have an option to make it much more than 3/4" due to it extending the surface out too far--aesthetic consideration. Another mystery here is that while you and Constantin apparently agree about some
wall systems solving the problem by having very thick external insulation, Lstiburek's charts say that the polystyrene rigid insulation loses its permeability after 1" of thickness.
Complicated stuff.
Thanks,
David0 -
Dry air is an indictation of
very high air leakage, often times. When outdoor air comes in to replace the leaked air and goes from 20F to 70F the relatively humidity drops to about 10 to 15% maikeing for a really dry home. Our big old two story frame that is heavily insulated with vapor barriers and well weatherstipped maintians about 40% relative humidity all winter, even with jsut the two of us living here.... not much internal moisture from showers, etc. In fact the fans must be used during showers, cooking, etc or the windows fog up.
Boilerpro
blower test last fall yielded .9 ACH
which isn't that leaky; and that was before we sealed the fireplace flue and blew in cellulose in early spring. we'll have to see how it is next winter. I always assumed the heat was drying out the air. (Back in the city it was REALLY dry with steam heat; always used a vaporizer at night.)
As for the polystyrene insulation, I guess I could pre-drill small holes in it before installation. Of course that gives insects access as well. Or somehow figure out if the 3/4" is permeable enough as it is.
Thanks,
David0 -
EIFS
DG,
EIFS stands for Exterior Insulation and Finish Systems. The product is also called synthetic stucco. Just do a google search and you can read many of the horror stories where it was applied incorrectly.
Bob0 -
Sorry for the late reply,
I have been out with work all of last week and I didn't notice this post before.
This is a hard decision, particularly as you are constrained to only 3/4" of insulation outside the clapboards. I have the feeling that the dewpoint may thus occur inside the home, requiring some permeability for the water to escpe.
I have found the folk at BuildingScience to be really friendly. I spoke to them re: my Radon collection system, so if I were in your shoes, I'd draw up the proposed wall construction, make notes about the local climate and then submit it to them to look over. Maybe they can make some good suggestions for free or a small fee.
I'd like to think that if you resort to dense-pack cellulose and seal the interior walls that the water permeation will be cut down significantly. A vapor barrier would be an obvious candidate but you may not be in the mood to tear down interior walls. Interestingly, they do offer VB paint for interior applications, though I have no idea how effective it actually is.
I'd like to think that if the interior is sealed and water no longer permeates outward that you should be fine with the layer of insulation on the outside, as long as the insulation allows the clapboards to dry out. However, I defer to the scientists... and followed their advice in building our wall systems.0 -
David
From a non-scientific point of view, even though it seems you have decided to go the vinyl route, I would not want to see another 'painted lady' get covered-up, wrapped-up, bound and gagged with vinyl. I own a similar house. A 1924 bungalow in Bergen County NJ...not far from the house you describe. I will be faced with a similar decision as the house will be in need of paint soon. Although the points you and others have made in this thread concern me, I think I will stay with the wood clapboards. I will scrape, smooth, plug and paint! A beautifully detailed pre-war house covered in vinyl, in plain english, looks like crap.0 -
That's a good point too...
... we chose the wood siding route because our GC was able to find a great deal of 17'-long clapboarding. The old stuff was too far gone to save, unfortunately.
I am surprised that the infra-red approach to remove the paint is very costly. The device is only $300 and with the helper screwed to the underside of your roof overhang, the progress is pretty quick because you push the heater to the next section while you work. Not an easy job, perhaps that's why your painter is not willing to do it for a easonable price.
Perhaps it's time to find a paint contractor who would be happy to remove the lead paint at a more reasonable price. I'm not a fan of vinyl either, I find the stuff doesn't look any good after just a few years and painting AFAIK is not an option.0 -
yeah we've been going back and forth on this awhile.
I have alot of the same sentiments. In case you weren't aware of the infra red paint remover.0 -
I have alot of the same sentiments. In case you weren't aware of the infra red paint remover here are the links.
The infra-red paint remover: http://www.silentpaintremover.com
The site lists contractors who use it.
This old house infrared red episode info: http://www.thisoldhouse.com/toh/print/0,17071,386353,00.html
As Constantin mentioned, the machine is relatively cheap. I thought of doing it myself --have to use scaffolding to do it right-- even one side a year. It would work best on a house that has multiple layers that's never been sanded. I called over Paul Marlowe of Marlowe Restorations.com in Northford CT for a consultation and he demonstrated the machine. The right scrapers are key. He was very helpful. My clapboards had been sanded various times, but it still worked pretty well. The two painters I spoke to don't like to use the accessory that hangs down; they work in pairs or threes. left, center right. one heats, two scrape.
It is amazing to me that as popular as vinyl is and with all the almost ridiculous variety there is in so many things in this country, they don't have 5" clapboards in lengths over 12 feet anywhere so you have double clapboard seams all over the place. People haven't demanded it and the result is alot of tasteless houses out there.
Thanks,
David0 -
David
Have seen those infared removers. Seem to be the best method so far. I have not used one myself though. AS far as cost, $300 dollars is a fraction of the total cost to repaint. If you were to repaint, seems like a minor investment...especially to do it the best and safest way!
Also, I dont mean to make you start doubting your decision at this point. But I will say this, if I were in your shoes, I would not be considering vinyl. I already know I will repaint. Just an opinion though.
Now, I havnt looked in detail at costs to install vinyl vs repainting but I would suspect vinyl is, or at least double the cost to paint? Assuming so, the cost of vinyl will pay for at least 2 paint jobs. If applied properly using a QUALITY paint you could perhaps get 8-10 years out of each paint job. Thats 16-20 years. The net difference to me is the vinyl covers up the beauty of the wood and look of the house.0 -
around here vinyl only maybe 25% higher than painting
that is if you hire licensed contractors with workman's comp insurance like I always do. Also this is not a victorian painted lady but a 20s colonial....we have projected the painting cost into the future and it comes out to be really expensive, but of course since we're in our 50s we thought how many more paint jobs could there possibly be?
I figure in a few years they'll come out with something in between vinyl and hardyboard.
thanks for your opinions,
David0 -
Siding
Here is a picture of my new house that I am building. The siding is pre finished smooth hardi plank 5" exposure. I made all of the trim myself from koma boards. The house is designed to look like an old craftsman style home.
I would never install plastic on this home.
beautiful work
I bet you can't wait to move in. Classic appearance--with a sleek new mod con in the basement I bet.
thanks,
David0 -
thanks but has almost no info on it
they seem to be plugging for dealers. They don't show any colors; I also don't see it on the approved and test list of the vinyl siding institute. I'll check it out though. There's a dealer in my town.
thanks,
David0 -
seamless
I dont know anything about the seamless siding just thought it looked interesting.
Good luck0
