rems t drill
ScottMP
Member Posts: 5,882
I have always looked at these tools but never bought one.
It appears that the "fitting" it makes is only about an eightth of an inch deep. Thats enough for a joint ??
It must be cause you guys use them ....
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Scott
is it a good tool
I have been trying to decide if i want to purchase a t drill. Is the one by rems a good investment? What sizes tees can i make with the rems?
I have always used the milwaukee one while working for other mechanical contractors but i cant seem to find one used under 1000$, so basically i am trying to decide if the rems is worth the money or should i keep saving?
REMS
The Accu-Press and Curvo have been quite impressive. Not cheap. I'd like to add their Tee drill soon & then I'll rarely use a fitting. "SWOOPY bends." Love the lack of pressure drop:-)
Which model?
I have the combo Twist/ Hurrican. It will pull tees up to 7/8" and expand tube (make couplings) to 7/8.
Be nice if it would pull 1-1/8.
It's not as high tech as the T-Drill brand. It takes two steps. It is much lighter and fits into tighter spaces than the T- Drill brand.
I have pulled hundreds of tees with mine. It's a very well built tool, as are all the REMS products. You can remove that hex adapter, purchase a chuck and use it as a corded drill. I believe Metabo makes the drill motor portion for REMS. Nice quality drill.
To be honest I do not use the expander all that much. Consider the Hurrican version.
Or the hand ratchet version Hurrican H.
hot rod
Suppose it depends...
... on how busy you're going to keep the tool. I've used a REMS kit for pulling 'T's for years. I only use it intermittantly, but for around $350, it was the right thing to get. I have had some trouble with sticky threads, but nothing too serious. My kit goes up to 3/4".
Yours, Larry0 -
Scott,
I assume we all silver braze these 1/8" joints we're talking about? I had a guy drop a roof on a pair of manifolds I made and they hold up very well. The joint will bend back and forth without coming loose. Since you can't silver braze the brass Pex fittings, (too much heat) I silver braze short 1 1/2" pieces of 1/2" copper and then soft sweat the brass adapters into those.
I have a Rothenberger that was about $400 and I use a large Hole Hawg drill to pull them quickly. It seems to be a good tool, but I was a bit disgusted that it doesn't come with an owner's manual of any sort. You can't even buy a $20 toaster without getting a pamphlet to tell you how to get the best service out of the thing. If I were going to try it again, I'd look at the Rems before I bought. Kevin0 -
Sure you can braze brass to copper
I prefer the Harris Blockade product for this as it has a lower melt point.
A gas fluxer also makes a nicer joint.
Manifolds from the manufactures have barbed brass adapters brazed into them. I have used Watts Radiant, Sioux Chief, Alberta T-Drill and these PHP brands.
As for the shallow socket, check out AC coils these days. Many have copper just drilled into, and brazed. Without a raised tee.
I believe there is a standard for pulled tees. I've seen it listed in T-Drill manuals and also at the CDA website.
T-Drill added a second dimple to their tool a number of years back to meet some military spec or something like that. I remember them running an ad campaign when that happened.
hot rod
I have a Rothenberger brand tee puller and a swaging tool from them also, they both work flawlessly you do have to be careful at first with tee puller but any drill works no special drill needed 1/2 chuck and your in. Swaging tool goes up to 1 1/4 as they may have bigger sizes. Haven't used a copper coupling in years and it works on dented fittings. I have soldered joints on pulled tees, but brazing is more peace of mind0
