Was it slow and steady that won the race?
shawn_11
Member Posts: 24
I re-vented the mains, vented the risers, and replaced some radiator vents that were old or ineffective. The house's heat is now well balanced, faster, more efficient, and under lower pressure.
But, I have two problems:
1) I now get expansion noises (creaking and some pops)that I didn't used to get. I assume this is because the pipes and radiators now heat up more quickly.
2) I hear the boiler's water feed more often (every few weeks). I wonder if this is because the water can boil off faster under lower pressure, and the boiler gets low faster than the condensate can get back to it.
So should I be worried, should I step down the vents?
I wouldn't worry about it
you're getting more expansion because the system is heating faster. Consider it "the sound of high efficiency".
Feeding once every few weeks isn't bad, but if it gets to be much more than that, start looking for a leak someplace.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
