Single pipe steam
Brad White_9
Brad White_9 Member Posts: 2,440
On the boiler side of things, Dante, steam generally is self-limiting to the low to mid 80's percentile. No condensing by definition, you are leaving the boiler with steam at 212F plus and nothing can be done about that.
That said, steam is a wonderful way to heat! Get your system to it's own personal best by venting correctly, insulating the piping, adding TRV vent valves to strategic radiators, cranking down the pressure using a vapor stat (ounces not pounds of pressure) etc. etc.....
What you have now can be made even better.
