News from B&G
NEW BULLETIN HIGHLIGHTS
BELL & GOSSETT 3-SPEED CIRCULATORS
MORTON GROVE, Ill… April 27, 2006 - A bulletin that describes
Bell & Gossett's new line of 3-speed NRF wet rotor circulators for residential and light commercial heating systems has just been released.
The bulletin (A-112C) presents detailed operating data and dimensions of the circulator pumps for hydronic heating systems. The new circulators - models NRF-36 and NRF-45 - are equipped with 3-speed motors, which allow the pumps to cover a wide range of hydraulic capabilities.
Benefits of the 3-speed NRF circulator line include:
o Three-speed switch provides more performance flexibility
o Multiple hydraulic settings allow one NRF pump to replace several competitors' pumps, resulting in lower inventory levels
o High starting torque
o Unique Bell & Gossett DuraGlide™ Bearing System
o Heat resistant and non-metallic closed impeller design
o Self-cleaning particle shield
The bulletin also includes diagrams that illustrate the product dimensions, as well as construction materials, maximum working pressure and operating temperature. A PDF file for bulletin A-112C can be downloaded at:
http://fhaspapp.ittind.com/Literature/files/4.pdf
ITT is a leading manufacturer of centrifugal pumps, circulators, hydronic specialties, heat exchangers, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact ITT at 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.
