low pressure switch
Justin Gavin_5
Heh Guys,
Its Justin (Seabee in the Desert),
Heh we have a 25 ton carrier and we had a leak coming off of the low pressure switch by the capillary by the switch. when trying to remove the switch we snapped off the well.
Anyways besides no availability of parts does anyone know what the part number is. I can't find a manual anywhere and we have to get the unit up. Its pretty critical.
It is a carrier 50TJ-028-933S.
Any help would greatly be appreciated.
Thanks in advance.
Justin Gavin
Thanks in advance.
Justin Gavin
Take a quick look
at you current pressure settings. Any supply house should be able to match you up with a wide variety of lo press switches. Is the switch like a 1" dia. x 2 or 3" blue or green tube or a standard adjustable type?
Mike T.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
