Radiant/Hardwood floors
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
over radiant:
http://www.warmboard.com/
http://www.hardwoodcouncil.com/tips/tip5.htm
http://www.woodfloorsonline.com/techtalk/woodwater7.html
http://www.heatinghelp.com/newsletter.cfm?Id=19
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Radiant/Hardwood Floors Help
any suggestion on how one of my customers can convince an 80 year old woman that radiant won't damage her hardwood floors?
thanks
R.G0 -
Hardwood associations
check with NAOFM and the hardwood flooring association.
Tim D.0 -
www.launstein.com
has some of the best testing info on hardwood and radiant I have seen. They built a lab specfically for testing wood flooring and radiant.
I believe they are about to release a 6-8" wide engineered hardwood product built up of all quartersawn layers.
hot rod
Well, not really ..*~/:)
i would also be a bit of a skeptic until you told me the water temp required and what Kind of radiant (floor?) you were talking about And what kind of control stradgey was being employed....is this a trick question > ?
get the information from ...
...the Hardwood Flooring Association and sell her a thermostat with Slab Sensor for Slab Maximum Surface Temperature Limitation so you can ensure it.
Regards,
Mike0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
