News from McDonnell & Miller
MCDONNELL & MILLER ANNOUNCES NEW WIRE HARNESS FOR RB-24
RESIDENTIAL LOW WATER CUT-OFFS
Chicago, Ill., July 13, 2005 - McDonnell & Miller has introduced an addition to its popular GuardDog family of residential low water cut-offs. The new Universal Wire Harness is designed for use with the M&M RB-24 low water cut-off for 24-volt residential hot water boiler applications.
The new field-assembled harness allows the installing contractor to plug directly into the OEM's wiring harness without cutting wires. This dramatically shortens installation time, saving time and money, and significantly reduces the chance for errors.
Two models are offered to accommodate different types of boilers. The UWH-RB-24-A is designed for most atmospheric boilers with 6-pin aquastats or vent damper manufactured by Effikal, Fields, Johnson Controls or Honeywell, while the UWH-RB-24-S is designed for sealed combustion boilers that use integrated burner controls from United Technologies or electronic aquastats from Honeywell. The M&M Series UWH-RB-24 wire harness kits can be applied to 80 percent of the 24-volt residential hot water boilers installed annually in the United States.
McDonnell & Miller
McDonnell & Miller, a unit of ITT Industries, is a leading manufacturer of boiler controls, flow switches, liquid level controls and steam specialty products for residential, commercial and industrial applications. For more information visit www.mcdonnellmiller.com, or call 773/267-1600, fax 773/267-0991.
Retired and loving it.
