Cast Rads
S Davis
Member Posts: 491
I am looking for BTU ratings for cast Rads at low water temps 90 to 130 degrees anyone know of a chart for this?
Thanks,
S Davis
Apex Radiant Heating
Thanks,
S Davis
Try Burnham's \"Heating Helper\"
I think it goes down to around 110 degrees or so.
You can google for "htghelper" to find it online.
-Michael
Cast Rads
Michael,
Thanks I had the book on the book shelf, but did not think to look at it.
S Davis
Apex Radiant Heating0 -
Serious Doubts About That Table
It's just a bit of a continuation of the "standard" table showing output dropping to 0 at 95° surface temp in a 70° room. ABSOLUTELY IMPOSSIBLE!!!
Under constant circulation and TRVs I have some rads in my house that NEVER exceed 95° while maintaining 68° room temp.
1.5 btu/hr/sqftEDR/degree of temp difference seems to work well for low temps. e.g. 95° rad in 70° room = 37.5 btu/hr/sqftEDR.
This number served VERY well using a traditional cast iron boiler. When I changed to a Vitodens, average radiator temps dropped. I appear to be getting outputs as high as 3½ btu/hr/sqft/degree temp difference. The "why" and the "how" of this leads me to very strange ideas.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
