Buderus w/ Riello High co?
Scott Kneeland
Member Posts: 158
gross was 385
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=339&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have a customer with a Buderus G115/5 with a Riello 40 f5. It has been 2 years since the last cleaning, I cleaned it used the .85x60b Delevan nozzle that they request and is the same nozzle that it has had all its life. Pump @180psi, head @3, air 2.75. Upon testing I have a 13.8 co2 and no smoke, a 33ppm co. and -.03 breach draft. tried another nozzle and had the same teat. If i increase the air to 3 or more it delays on start. I brought the head back to the 1 that they suggest and the co2 goes to 14.3.
Any Ideas?
Scott, at what CO2 level
do you start making smoke?All Steamed Up, Inc.
Consulting0 -
13.8 sounds normal for that set up. What was your stack temp?
buderus boiler
the company i work for pushes the burnham v-8 as their top of the line and pennco/dunkirk for lower cost boiler, i am trying to get my boss to try some buderus boilers.. i like the way they are built and they seem to have good people working for them, [ meet some at hershey show.] but i get gun shy with what seems like alot of problem set ups with riello/buderus comb. i have good luck with riellos but is carlin or beckett a better choice for this boiler???does direct venting make burner choice change??0 -
most of the Buderus in this area are the 3 and 4 section and most all with Riello, most of them run 11.7 to 12.4 that I can live with but 13.8? maybe I'm just to old school.
I like the Riello with the Buderus and setup is "usually easy" however this one is running fine just high co2. I have seen this with the Dunkirk 3E100 series with the L head Beckett also 13.0 to 13.4 co2
Buderus ratings are based on a 13% CO2. Smooth light off, 33ppm, zero smoke, I'm comfortable with that. With an 86%afue you have to have a low stack temp and high CO2. I have several that I service. Year to year they are very clean inside.
Maine Ken
The higher the CO2 with zero smoke, the better, not worse.
Ron0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
