Ultra stuck at 70?
Tony_23
Tony_23 Member Posts: 1,033
Do you mean the outlet temp is 70 ?
  • hr
    hr Member Posts: 6,106
    Seems to be locked in low fire
    it's an over the phone troubleshoot, any ideas.
    Settings seem to be correct for heating and DHW. One zone with thermostat connected to boiler and boiler pump wired to boiler pump connections.
    No outdoor reset sensor connected boiler operating temperature set at 140.
    Being used for construction heat, system pump runs continuously, wall stat just calls on boiler and primary pump.
    Thanks for any thoughts.
    hot rod
  • Uni R
    Uni R Member Posts: 663
    Intake air restriction...
    Did anything obstruct the intake air path?
