Steam boiler control
Peter- I usually pick a Honeywell Vaporstat for low pressure applications. Don't know where you live so I can't be of much use to you as to a supplier-let us know, I'm sure someone here can help with that.
  • Low Pressure Steam boiler control
    I am looking for a low pressure control for a residential boiler. I want to control the steam pressure from 1 - 2 psig. The adjustments on the boiler is .5 - 9 psig and will not operate well at the lower end of the scale.
    Any recommendations on where I could find a control for very low settings?
    Thanks,
    Peter
