can homeowner measure rads for edr?
thfurnitureguy_4
Member Posts: 398
Try this http://www.colonialsupply.com/resources/radiator.htm
How would a homeowner measure radiatrs for EDR calc? I,m trying to research what I will need prior to getting estimates to replace old steam heat boiler.
ja0 -
Dan has a book on this site you can order to get the EDR of most rediators. If you go on the Burnham web site and find the "Tool Box" there will be a link to charts to size standard old cast iron and thin radiators. I think the link is called Sizing Obsolete Radiation. Don't have the link here at work.
Edit: I see that thefurnitureguy just gave you another link. I will compare that one to the Burnham one. Thanks.0 -
Bob let me know what you find. It was an easy chart to learn the basics0 -
edr for \"obsolete \" radiators
the colonial supply website was great- now I know that I have column and wall type radiators. Burnham allowed you to print a sizing fill-in chart.
thanks-ja0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
