Heat won't stop?
CO Testing Biz?
Member Posts: 14
I HAVE CONSTENT HEAT. FOUND THE EXP. TANK WATER LOGGED, WOULD THIS BE MY PROBLEM OR THE FLOW CHECK? OR BOTH. IT SEEMS TO BE GRAVETY FEED. THERMOSTATE IS OFF AND STILL GETTING HEAT. IF IT IS THE ABOVE ANY IDEAS ON FIXING THE FLOW CHECK RATHER THAN REPLACING IT?........RF
HELP....PLEASE SEE HEAT WONT STOP!!!0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
