air flow check valve
Rob Burt
Member Posts: 1
I am installing a new corn burning furnace, and want to use the existing duct work. Should I install some type of a reverse floe check valve so when the existing furnace comes on it will not force air back into the new furnace?
Thanks Ron
Thanks Ron
Yes, A
Duct damper . you most likely can get one that'll fit. look for a sheet metal fabricating shop. they'll have or get what you need0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
