Sealing Steel Pipes
Good Morning,
My friend and I are replacing my hot water boiler and we are having a problem with the steel pipe fittings and dielectric unions leaking when the system comes up to full heat and around 15 PSI pressure. We used pipe dope on all joints but it seems to be bubble through. Also, the rubber gaskets seem to be leaking on one of the unions.
Any advise?
Thank you! Adrien
